Our oven door is broken. First, It wasn't closing all the way and then finally the door fell off. The handle broke when the door fell on the floor. We removed the door to fix the handle. While we were trying to fix the handle, the glass shattered. I would like to know if I can purchase just the door itself, just the glass or do I need to purchase a whole new oven. Thank you for your help.
THIS FORUM IS DEAD!!!!!!! |
Thank you so much. We found the parts we need. But now I have a new question. The reason we had to remove the door was because the oven door wasn't closing all the way. We are still going to have a problem with the door not closing all the way. How can we make the door close all the way?
Thanks!
[COLOR="DarkRed"] We are still going to have a problem with the door not closing all the way. How can we make the door close all the way?[/COLOR] Check the hinges perhaps one of them has a problem. Often just removing the door and re-installing it fixes closing problems as one or both of the hinges have slipped out of alignment. Be sure to use the recommended procedure for reinstalling the door. I rare instances the hinge receiver has a problem. |
