DJrFam
#1 Posted : 14 years ago
DJrFam
Our oven door is broken. First, It wasn't closing all the way and then finally the door fell off. The handle broke when the door fell on the floor. We removed the door to fix the handle. While we were trying to fix the handle, the glass shattered. I would like to know if I can purchase just the door itself, just the glass or do I need to purchase a whole new oven. Thank you for your help.
#2 Posted : 14 years ago
DJrFam
#3 Posted : 14 years ago
DJrFam
Thank you so much. We found the parts we need. But now I have a new question. The reason we had to remove the door was because the oven door wasn't closing all the way.
We are still going to have a problem with the door not closing all the way.
How can we make the door close all the way?
Thanks!
#4 Posted : 14 years ago
[COLOR="DarkRed"]
How can we make the door close all the way?[/COLOR]
Check the hinges perhaps one of them has a problem.
Often just removing the door and re-installing it fixes closing problems as one or both of the hinges have slipped out of alignment. Be sure to use the recommended procedure for reinstalling the door.
I rare instances the hinge receiver has a problem.
Whirlpool oven door latch motor (Oven Repair (including Ranges and Cooktops))
by sparkync 10 years ago
Whirlpool Oven Door Hinges Continuously Fail (Oven Repair (including Ranges and Cooktops))
by togamac 12 years ago
Whirlpool oven door removal (Oven Repair (including Ranges and Cooktops))
by ts756 13 years ago
Whirlpool oven door light switch (Oven Repair (including Ranges and Cooktops))
by Jim Yoshino 13 years ago
Whirlpool oven door fell off (Oven Repair (including Ranges and Cooktops))
by richappy 14 years ago
Whirlpool Oven Door Latch (Oven Repair (including Ranges and Cooktops))
by rwbil 14 years ago
Need help assembling Whirlpool oven door handle (Oven Repair (including Ranges and Cooktops))
by SauravSengupta 14 years ago
Whirlpool Oven Door Glass Removal (Oven Repair (including Ranges and Cooktops))
by hkrauss 15 years ago
Whirlpool oven door hinge pins (Oven Repair (including Ranges and Cooktops))
by Earnesttphdthc 16 years ago
Whirlpool Oven Door Help (Oven Repair (including Ranges and Cooktops))
by RitaCStanley@aol.com 16 years ago
Whirlpool Oven Door Switch - How To Replace? (Oven Repair (including Ranges and Cooktops))
by amorak 16 years ago
Need Help With Whirlpool Oven Door (Oven Repair (including Ranges and Cooktops))
by Wardog1958 16 years ago
whirlpool oven door (Oven Repair (including Ranges and Cooktops))
by ronald 17 years ago
Whirlpool oven door too hot (Oven Repair (including Ranges and Cooktops))
by danmari5 17 years ago
Loose Whirlpool Oven Door Handle (Oven Repair (including Ranges and Cooktops))
by konaboy 17 years ago
