hkrauss
#1 Posted : 15 years ago
hkrauss
Hi - I want to remove the outer oven door glass to clean the inside of it. I have taken out all visible screws (6 total) and can't get the glass to come off. What am I missing? Thank you for your help.
#2 Posted : 15 years ago
Have you removed the door from the oven?
The first thing which has to be removed is the inner door liner.
hkrauss
#3 Posted : 15 years ago
hkrauss
How do I do that?? I've removed all the screws that I can see. Looks like the brackets that hold on the handle are keeping the whole thing from coming apart, but the brackets are behind the glass and the screws enter from the inside meaning that I will have to remove the glass to be able to remove the handle.
#4 Posted : 15 years ago
The door removal instructions are in the Owner manual (page 13).
Put the door on a flat surface with the door handle facing down.
