summer081905
#1 Posted : Monday, December 29, 2008 4:20:56 PM(UTC)
summer081905
The dryer is working and drying clothes but making thumping and pounding noise. I have check the belt around the drum it looks fine. I repaired the motor about a year ago.
Drags1998
#2 Posted : Monday, December 29, 2008 4:24:36 PM(UTC)
Drags1998
Replace the rear drum rollers!!!! This should do it!!!:)
dryer works for 30 seconds and shuts off with no heat coming back on (Dryer Repair)
by egeving 6/16/2021 8:31:38 PM(UTC)
Maytag MDG9706AWW Dryer works intermittently (Dryer Repair)
by howiehangg 1/25/2019 9:26:39 AM(UTC)
Admiral electric dryer works 5seconds, stops (Dryer Repair)
by ddrepairdog 7/24/2016 1:17:38 PM(UTC)
dryer works but won't turn off (Dryer Repair)
by dilbe14674 7/13/2015 7:20:37 AM(UTC)
Dryer works intermittenly (Dryer Repair)
by steveoreno 5/16/2015 6:12:45 PM(UTC)
dryer works fine & then doesnt until I unplug/plug back in (Dryer Repair)
by boothejennifer 7/19/2014 8:42:43 AM(UTC)
Roper dryer works fine but makes an awful noise (Dryer Repair)
by bwthompson 2/2/2014 12:53:31 PM(UTC)
Dryer Works Well But Timer Dial Does Not Advance (Dryer Repair)
by whudsonemt 9/15/2013 2:22:45 PM(UTC)
Gas dryer works fine at first them flame dies during re-ignition (Dryer Repair)
by pvr2002 9/14/2013 12:30:42 PM(UTC)
Dryer works on med heat only (Dryer Repair)
by Pat Sanders 4/10/2013 3:54:17 PM(UTC)
Dryer works fine for 5 minutes, then heat quits. (Dryer Repair)
by Motordoctor 1/4/2013 12:34:31 PM(UTC)
dryer works but will not 'heat-up' to dry the clothes (Dryer Repair)
by man599 9/8/2012 8:47:33 PM(UTC)
& Year Old Hotpoint Dryer Works on 1 Cycle and don't shut off (Dryer Repair)
by wyocwboy 8/3/2012 5:29:00 AM(UTC)
dryer works on and off (Dryer Repair)
by tmk 6/21/2012 2:08:43 PM(UTC)
dryer works then dont (Dryer Repair)
by nickhere 3/6/2012 11:13:09 AM(UTC)
