upon initial start of the dryer flame turn on heats up then shuts off when it goes to cycle on again it wont. Which sensor is stopping this.
I did a no load it turn on and off twice
Originally Posted by: nickhere  upon initial start of the dryer flame turn on heats up then shuts off when it goes to cycle on again it wont. Which sensor is stopping this.
I did a no load it turn on and off twice Nick, It's not likely any sensor is faulty. My guess is that the flame on the burner cycles on then off a couple of times. Then cycles on, but there is no flame on the burner. This would indicate a weak gas valve coil(s) Part number: AP3094251
on the valve assembly. Good Luck and Thanks, :) :) :)
I would think the coils to if the flame never came on but it does
Originally Posted by: nickhere  I would think the coils to if the flame never came on but it does Nick, The coils are basically a wire wrapped around a cylinder, when power is applied to the wire, the coil becomes an elctric magnet and lifts the plunger inside the gas valve. If the wire develops a "weak" spot, it will cycle off and on until the weak spot separates and the circuit is broke, when the coil cools off th wire will make contact and operate until the wire gets hot and separates again. If you have a multimeter, you can check the coil resistance, if you wish : The two terminal coil should have a resistance reading of 1000 to 1,300 ohms resistance. The three terminal coils should have a resistance of 1300 to 1400 ohms resistance between pin 1 and pin 2 and 500 to 600 ohms, pin one to pin 3, when cold. Once you run the dryer until the flame no longer ignites and repeat the same test, I'm pretty sure you'll find no resistance on one of the coil circuits( if you're fast enough, or run the dryer long enough). Thanks and good Luck, :) :) :)
yep it the coil it sticking knock it around and it working
Originally Posted by: nickhere  yep it the coil it sticking knock it around and it working Nick, Ok, so now you need to order the coils and get them installed. Your description, indicates the split coil(three terminal coil) is at fault, but replace them both. :) :) :)
