lovenaz1940
#1 Posted : Tuesday, March 8, 2011 12:01:32 PM(UTC)
lovenaz1940
neither bake or broil elememts heat. control panel appears normal.
magician59
#2 Posted : Tuesday, March 8, 2011 12:15:51 PM(UTC)
magician59
Kind of unusual for both elements to fail at the same time. Pull out the range and test for 220VAC at each element witha bake/broil selected. If you don't measure it there, you probably need to replace the clock.
Part number: AP5176341
lovenaz1940
#3 Posted : Tuesday, March 8, 2011 1:16:16 PM(UTC)
lovenaz1940
no voltage at bk. or brl. terminals. have 246 across L1-L2.
L2 out is also dead.
magician59
#4 Posted : Tuesday, March 8, 2011 1:41:27 PM(UTC)
magician59
Sounds like the clock is the culprit.
frigidaire wall oven 6564063 (Oven Repair (including Ranges and Cooktops))
by Guest 7/2/2024 12:40:53 PM(UTC)
Replacing oven bake burner on GE JCB920BEC4BB (Oven Repair (including Ranges and Cooktops))
by Guest 6/30/2024 7:37:19 AM(UTC)
GE Profile Oven heating very slowly (Oven Repair (including Ranges and Cooktops))
by Reddogmatic 6/23/2024 4:53:08 PM(UTC)
Frigidaire oven won’t heat (Oven Repair (including Ranges and Cooktops))
by Jseeders 6/16/2024 10:23:51 AM(UTC)
Whirlpool Oven/Microwave combo E1 F2 (Oven Repair (including Ranges and Cooktops))
by MalcolmR 6/12/2024 10:02:00 AM(UTC)
Recommend gas range single oven (General Talk)
by 007noob 6/10/2024 3:19:57 PM(UTC)
Solved: Removing microwave unit from wall mounted Oven/Microwave combo (Oven Repair (including Ranges and Cooktops))
by MalikR 6/10/2024 3:04:18 PM(UTC)
Whirlpool Gold Accubake Oven/Microwave (Oven Repair (including Ranges and Cooktops))
by Guest 6/10/2024 10:21:28 AM(UTC)
GE Wall Oven Model PT7800SH9SS (Oven Repair (including Ranges and Cooktops))
by 68catcar 5/21/2024 6:06:03 PM(UTC)
NEITHER OVEN NOR BROIL BURNER LIGHTS (Oven Repair (including Ranges and Cooktops))
by roastbredfruit 5/21/2024 3:00:41 PM(UTC)
Kitchenaid Oven range Superba kgsc308lss0 not heating up (Oven Repair (including Ranges and Cooktops))
by rattty 5/19/2024 6:51:16 PM(UTC)
Frigidaire oven issue (Dishwasher Repair)
by Guest 5/8/2024 12:45:18 PM(UTC)
Thermador double oven from '99 troubleshoot (Oven Repair (including Ranges and Cooktops))
by mike_balt 5/6/2024 4:16:42 PM(UTC)
How to pull microwave out of mw/oven combo (Oven Repair (including Ranges and Cooktops))
by cromking 5/6/2024 1:13:05 PM(UTC)
Samsung Range Overheating Oven (Oven Repair (including Ranges and Cooktops))
by ajerwin 5/6/2024 4:34:22 AM(UTC)
