childersjones
#1 Posted : Thursday, February 24, 2011 2:58:58 PM(UTC)
childersjones
Wall oven has digital display touch control panel showing correct time. When I touch button to turn on oven and set temperature, "bake" and "on" are displayed along with current temperature. Oven begins to heat but after 1-2 minutes oven and display shuts off. Clock continues to show correct time. What's wrong?
Jeff / APP Team
#2 Posted : Friday, February 25, 2011 12:30:26 PM(UTC)
Jeff / APP Team
You will need to uninstall the oven and remove the back panel. There you will find a limit switch. Test this switch with a multi-meter it should read closed or 0 for continuity. If it is open, replace this part. Part number: AP2023958
childersjones
#3 Posted : Friday, February 25, 2011 6:10:38 PM(UTC)
childersjones
Followed instructions given to test limit switch. Meter read 0 (closed) indicating it was OK. Any other suggestions?
Jeff / APP Team
#4 Posted : Monday, February 28, 2011 7:32:20 AM(UTC)
Jeff / APP Team
Did you test the elements and make sure they are good? Also make sure you have 240 volts coming to the unit.
Viking gas range oven troubleshooting (Oven Repair (including Ranges and Cooktops))
by MK_ 3/3/2024 10:10:13 AM(UTC)
Double Oven Trouble (Oven Repair (including Ranges and Cooktops))
by kctypes4u 9/19/2014 10:56:33 AM(UTC)
oven trouble (Oven Repair (including Ranges and Cooktops))
by steve79 6/15/2014 7:14:39 AM(UTC)
jenn air double oven trouble (Oven Repair (including Ranges and Cooktops))
by suelorio 12/2/2013 4:49:26 PM(UTC)
by ikey 12/16/2012 4:42:48 PM(UTC)
Caloric oven troubled (Oven Repair (including Ranges and Cooktops))
by vw66guy 12/9/2012 2:21:19 PM(UTC)
Jenn-air oven troubles (Oven Repair (including Ranges and Cooktops))
by SteveDB 10/8/2011 8:46:43 PM(UTC)
electric oven troubleshooting (Oven Repair (including Ranges and Cooktops))
by prousseau 2/18/2011 6:27:10 AM(UTC)
by mcdrell 9/15/2010 11:49:06 AM(UTC)
amana oven trouble (Oven Repair (including Ranges and Cooktops))
Belarus keithoak1 3/15/2010 5:22:58 AM(UTC)
by enzo731 5/29/2009 2:43:06 PM(UTC)
by nhoj 3/19/2009 2:29:03 PM(UTC)
whirlpool double oven trouble (Oven Repair (including Ranges and Cooktops))
by xmasvalley 1/24/2009 11:35:05 AM(UTC)
GE Oven Trouble (Oven Repair (including Ranges and Cooktops))
by at123 11/29/2008 10:18:40 AM(UTC)
