Wall oven has digital display touch control panel showing correct time. When I touch button to turn on oven and set temperature, "bake" and "on" are displayed along with current temperature. Oven begins to heat but after 1-2 minutes oven and display shuts off. Clock continues to show correct time. What's wrong?
You will need to uninstall the oven and remove the back panel. There you will find a limit switch. Test this switch with a multi-meter it should read closed or 0 for continuity. If it is open, replace this part. Part number: AP2023958
Originally Posted by: Jeff / APP Team You will need to uninstall the oven and remove the back panel. There you will find a limit switch. Test this switch with a multi-meter it should read closed or 0 for continuity. If it is open, replace this part. Part number: AP2023958
Followed instructions given to test limit switch. Meter read 0 (closed) indicating it was OK. Any other suggestions?
Did you test the elements and make sure they are good? Also make sure you have 240 volts coming to the unit.
