kctypes4u
#1 Posted : Friday, September 19, 2014 10:56:33 AM(UTC)
kctypes4u
Help!
My circuit board for this model started smoking the other evening. We suspect it's not fixable. (sob). My question - If we remove the damaged board from the upper oven, would we still be able to use the lower oven until we find a replacement? (this oven has dials for controls).
Thank you!
KC
#2 Posted : Tuesday, September 23, 2014 12:53:06 AM(UTC)
[COLOR="Blue"]If we remove the damaged board from the upper oven, would we still be able to use the lower oven until we find a replacement?[/COLOR]
Yes you should be able to use it.
You have to make sure that any wire yoy remove from the board cannot short to anything else.
Looks like the control board is obsolete.
File Attachment(s):
RB270.pdf (246kb) downloaded 2 time(s).
jenn air double oven trouble (Oven Repair (including Ranges and Cooktops))
by suelorio 12/2/2013 4:49:26 PM(UTC)
whirlpool double oven trouble (Oven Repair (including Ranges and Cooktops))
by xmasvalley 1/24/2009 11:35:05 AM(UTC)
