enzo731
#1 Posted : Friday, May 29, 2009 2:43:06 PM(UTC)
enzo731
oven does not work oven igniter is glowing and warms up how do i kwow if its bad.
applianceman
#2 Posted : Friday, May 29, 2009 5:47:37 PM(UTC)
applianceman
You must have an amp-meter to check the igniter. If you have one the igniter should draw 3.4-3.6 amps to open the gas valve if not the igniter. If it is drawing this amount of current I would say the gas valve is bad. Gas Oven Repair Guide
Viking gas range oven troubleshooting (Oven Repair (including Ranges and Cooktops))
by MK_ 3/3/2024 10:10:13 AM(UTC)
Jenn-air oven troubles (Oven Repair (including Ranges and Cooktops))
by SteveDB 10/8/2011 8:46:43 PM(UTC)
electric oven troubleshooting (Oven Repair (including Ranges and Cooktops))
by prousseau 2/18/2011 6:27:10 AM(UTC)
by nhoj 3/19/2009 2:29:03 PM(UTC)
