discher
#1 Posted : Wednesday, February 23, 2011 4:14:36 PM(UTC)
discher
The washer runs through all cycles but on the spin cycle the agitator just jerks real slowly and there is a loud grinding/rubbing sound. I replaced the clutch but same problem continues. Water is pumped out ok, it just won't spin.
murderurfriends
#2 Posted : Friday, February 25, 2011 9:45:53 AM(UTC)
murderurfriends
Could be a bad transmission. Any oil leaked out anywhere? Also could be bad ears on the drive tube or bad. Drive block
#3 Posted : Friday, February 25, 2011 1:31:01 PM(UTC)
Pull the pump and turn the motor shaft clockwise. The clutch should engage and start turning, if not, you have a bad coupler and probably bad brake shoes.
murderurfriends
#4 Posted : Friday, February 25, 2011 4:21:21 PM(UTC)
murderurfriends
Probably would have noticed a bad coupler in the process of replacing the clutch though
#5 Posted : Friday, February 25, 2011 5:18:06 PM(UTC)
I disagree, something jammed would bust the coupler as soon as it starts up!
Spin Cycle Problems (Washer Repair)
by btmullaney 11/21/2014 5:10:45 AM(UTC)
GE Spacemaker spin cycle problems (Washer Repair)
by Kristal9 6/16/2013 8:17:51 AM(UTC)
by Amy Pirrone 8/24/2011 8:36:34 AM(UTC)
Kenmore Spin Cycle problems (Washer Repair)
by mmerr 1/29/2011 7:48:04 AM(UTC)
GE Washer Spin Cycle Problems (Washer Repair)
by jodava 5/19/2010 1:08:39 PM(UTC)
Belarus matt wyatt 1/13/2010 1:20:09 PM(UTC)
Roper spin cycle problems. TIA! (Washer Repair)
by K.D. 1/7/2010 1:42:11 PM(UTC)
by Buckeye JIm 1/7/2010 9:02:20 AM(UTC)
Filling, Agitator and Spin cycle problems (Washer Repair)
by pz7rx8 12/30/2008 10:34:02 AM(UTC)
