rfridley1
#1 Posted : Tuesday, February 22, 2011 6:45:27 AM(UTC)
rfridley1
Intially temp had to be set at 380 or above to come on, now it dosent work at all, I was told it could be a bad thermostat, does anyone have an answer?
Jeff / APP Team
#2 Posted : Tuesday, February 22, 2011 11:37:20 AM(UTC)
Jeff / APP Team
Will broil work on the unit? If so you could have a bad control board. If you test across the wires going to the bake element. You should have 240 volts when in bake mode. If you have 240 volts, then check the element. As far as the temp goes, you need to test the temp probe. It should ohm out around 11,000 ohms or less at room temperature. Let us know what you find.
GE Hotpoint Stove Bake Element not working (Oven Repair (including Ranges and Cooktops))
by Guest 3/21/2023 10:17:36 AM(UTC)
Bake Element not working everything else fine (Oven Repair (including Ranges and Cooktops))
by DBLTRAUMA 12/31/2016 5:24:27 AM(UTC)
Bake element not working in double oven (Oven Repair (including Ranges and Cooktops))
by luck11 1/11/2015 7:45:26 AM(UTC)
Bake element not working (Oven Repair (including Ranges and Cooktops))
by mcclelland 1/10/2015 12:20:06 PM(UTC)
by rrg1965 3/3/2014 9:37:12 AM(UTC)
Frigidaire wall oven, bake element not working (Oven Repair (including Ranges and Cooktops))
by Fred V 10/30/2013 5:59:41 PM(UTC)
Bake element not working. Thermostat or Controller board? (Oven Repair (including Ranges and Cooktops))
by leorosi 5/12/2013 4:40:07 PM(UTC)
by clwcomp 7/17/2012 9:06:35 AM(UTC)
Bottom bake element not working (Oven Repair (including Ranges and Cooktops))
by oldmill 6/2/2012 7:56:34 AM(UTC)
GE oven bake element not working, broil works. (Oven Repair (including Ranges and Cooktops))
by HelpMeAnyone 12/25/2011 3:39:09 PM(UTC)
Oven Bake element not working (Oven Repair (including Ranges and Cooktops))
by NickJade 11/14/2011 8:17:42 AM(UTC)
by apps2777 5/26/2011 8:56:52 AM(UTC)
Replacement bake element not working (Oven Repair (including Ranges and Cooktops))
by Bex291 1/12/2011 5:53:48 PM(UTC)
Bake element not working - Broil is fine. (Oven Repair (including Ranges and Cooktops))
by dank_01 3/10/2010 8:21:05 PM(UTC)
Wall oven bake element not working! Broil works, clock works. (Oven Repair (including Ranges and Cooktops))
by ajachyra 12/1/2009 1:37:54 PM(UTC)
