Does the dryer heat correctly? if it does, replace the timer, If not, find out why the heat isn't working.
Does it not advance in both timed dry and auto? The two cycle types use different circuit paths to power the timer. Here is the tech sheet https://www.servicematters.com/d...0Sheet%20-%208528187.pdfTimed Dry Neutral, DOOR SWITCH, TIMER SWITCH 0R/TM, TIMER MOTOR, TIMER SWITCH BU/BK, L1 Auto L2, DRIVE MOTOR switch 2M/1M, HEATER, RESISTOR, TIMER SWITCH WB/TM, TIMER MOTOR, TIMER SWITCH BU/BK, L1 Timer only gets power when the heater is off The resistor drops the 240 down to 120 for the timer |
THIS FORUM IS DEAD!!!!!!! |
