jackpetty72@yahoo.com
#1 Posted : Wednesday, December 17, 2008 2:18:12 PM(UTC)
Timer does not advance.
Drags1998
#2 Posted : Wednesday, December 17, 2008 2:37:39 PM(UTC)
Drags1998
Does the dryer heat correctly? if it does, replace the timer, If not, find out why the heat isn't working.
#3 Posted : Wednesday, December 17, 2008 4:40:36 PM(UTC)
Does it not advance in both timed dry and auto?
The two cycle types use different circuit paths to power the timer.
Here is the tech sheet
https://www.servicematters.com/d...0Sheet%20-%208528187.pdf
Timed Dry
Neutral, DOOR SWITCH, TIMER SWITCH 0R/TM, TIMER MOTOR,
TIMER SWITCH BU/BK, L1
Auto
L2, DRIVE MOTOR switch 2M/1M, HEATER, RESISTOR, TIMER SWITCH WB/TM, TIMER MOTOR, TIMER SWITCH BU/BK, L1
Timer only gets power when the heater is off
The resistor drops the 240 down to 120 for the timer
Whirlpool dryer timer knob (Dryer Repair)
by robertjhebert 10/27/2019 8:50:18 AM(UTC)
Whirlpool dryer timer won't stop running. (Dryer Repair)
by ppipowerclass 4/2/2018 2:18:22 PM(UTC)
Whirlpool Dryer Timer not advancing (Dryer Repair)
by jconkl02 5/9/2016 9:47:22 AM(UTC)
Whirlpool dryer timer (Dryer Repair)
by Dan4180 12/13/2015 7:24:28 AM(UTC)
by 68Vert 11/11/2011 4:41:57 PM(UTC)
Whirlpool dryer timer cycle endless (Dryer Repair)
by PAplumber 7/23/2011 10:42:35 AM(UTC)
Whirlpool dryer timer won't work sometimes (Dryer Repair)
by Baudretsch 12/18/2010 4:37:48 PM(UTC)
whirlpool dryer timer (Dryer Repair)
by junior10 11/21/2010 8:30:30 AM(UTC)
Whirlpool Dryer timer test good but not working (Dryer Repair)
by ctbasscatcher 9/4/2010 11:23:15 AM(UTC)
Whirlpool dryer timer advances occasionally, but usually does not shut off (Dryer Repair)
by lynndicken 8/19/2010 5:13:23 AM(UTC)
Whirlpool Dryer Timer not advancing / no heat (Dryer Repair)
by lady 11/19/2009 4:56:47 PM(UTC)
Whirlpool Dryer Timer Wiring (Dryer Repair)
by leeke02 9/11/2009 4:09:39 AM(UTC)
whirlpool dryer timer not moving (Dryer Repair)
by jonathan8 3/26/2009 6:00:58 AM(UTC)
Whirlpool Dryer timer runs backwards (Dryer Repair)
by PattyL 3/24/2009 10:36:58 AM(UTC)
Whirlpool Dryer Timer Fails to Advance. Heat? Well, sometimes. (Dryer Repair)
by XtremeRob 2/9/2008 8:07:08 AM(UTC)
