AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Whirlpool Dryer timer test good but not working
Hi The timer isn't working so I tested it, to make sure I did it right here's how...
Turned breaker off (220v) Removed one lead, put the clips on both power leads, set multimeter to ohms, turned timer on and the multimeter read 0. From what I've read this means the timer is good.
The dryer heats fine, but timer doesn't work in either Accudry setting or timed drying setting.
Any ideas on what would be my next step?
Nobody has any ideas? Any help? thx
Dryer Repair
