3 Pages<123
Guest
#21 Posted : Thursday, January 25, 2024 12:15:15 PM(UTC)
Guest
Rank: Guest
United States
THX for the details on testing the RPM- huge help. Mine were running over 3K. Thermador double oven (SEC model 2005). I have been receiving F64 codes and they were getting worse and worse. I flipped the breaker to the oven, stacked cinder blocks and wood in front of the oven, and slide it out onto blocks. I then pulled off the back and top to access the fans. I used a shopvac, toothbrush, 100 (seemingly) Q-Tips, and a acetone. I gently scrubbed the fan blades until shiny. The amount of junk that came off was incredible- cups of junk. I put everything back and did a fan test- 2400. Oven has been running for over an hour at 400. I searched everywhere and this is the only place with accurate info- THANK YOU!
Guest (5)
Thermador oven won't start self clean (Oven Repair (including Ranges and Cooktops))
by beb123 2/6/2024 7:34:41 PM(UTC)
Heating issues with Thermador Oven (Oven Repair (including Ranges and Cooktops))
by Guest 1/9/2024 4:34:19 AM(UTC)
Thermador oven temperature fluctuates (Oven Repair (including Ranges and Cooktops))
by tylert 7/4/2022 1:19:07 PM(UTC)
Thermador Oven issues PGR36GL (Oven Repair (including Ranges and Cooktops))
by aquasport 8/23/2020 1:15:43 PM(UTC)
Thermador oven not working DP366CS/03 (Oven Repair (including Ranges and Cooktops))
by Chanmomu 6/30/2020 5:07:14 AM(UTC)
Thermador Oven Selector Knob at Broil Shuts Off oven (Oven Repair (including Ranges and Cooktops))
by dviladvct1 1/1/2020 11:29:47 AM(UTC)
Thermador Oven Not Turning On- Tech no help (Oven Repair (including Ranges and Cooktops))
by annie1123 10/15/2019 5:11:58 PM(UTC)
Thermador oven help (Oven Repair (including Ranges and Cooktops))
by Lepetitmatin 8/16/2019 6:08:48 PM(UTC)
Thermador oven won't fire up (Oven Repair (including Ranges and Cooktops))
by cattleclass 11/18/2017 7:24:30 PM(UTC)
by Gandv 9/22/2017 6:21:58 AM(UTC)
Thermador oven stopped working (Oven Repair (including Ranges and Cooktops))
by ajappliance 8/15/2016 8:17:57 AM(UTC)
Thermador Oven Inop (Oven Repair (including Ranges and Cooktops))
by JakeM7pilot 10/15/2015 11:00:32 AM(UTC)
Thermador Oven error codes (Oven Repair (including Ranges and Cooktops))
by jblake9000 9/25/2015 9:01:34 AM(UTC)
Thermador oven won't regulate (Oven Repair (including Ranges and Cooktops))
by stanmac 1/20/2015 3:55:29 PM(UTC)
Thermador oven door won't close tightly (Oven Repair (including Ranges and Cooktops))
by fixitboy 11/26/2013 12:22:35 PM(UTC)
3 Pages<123
