aquasport
#1 Posted : Sunday, August 23, 2020 1:15:43 PM(UTC)
aquasport
I have a Thermador PGR36GL - I had a power surge that burned out the control board (980-102-05) - A visual inspection found burn circuit board traces. The symptoms of the burned-up board are
- Thermostat needle goes to 500 degrees
- Oven and oven fan turn on
- I hear the igniter and gas ignite
- Turns off after 30 seconds
- Blinking blue light 1-1
- Stove, Grill and boiler burner are working
I purchase a replacement board (980-102-07) it doesn’t work but show different symptoms. Is the replacement board bad? The symptoms of the new board are
- Thermostat needle is at zero – good
- I hear the igniter and the gas ignite – feel the oven getting hot
- THE OVEN FAN DOESN’T START
- No blinking lights
