griz369
#1 Posted : Tuesday, February 15, 2011 1:19:09 PM(UTC)
griz369
I am having issues with my dishwasher not wanting to start most of the time. A good while back some of the lights quit working on the keypad but it washer still worked fine, but now most of the time it won't start when you press the start button. Sometimes we can come back a little while later and press it again and it might start, sometimes. So do you think I need to replace the keypad panel or could it be the circet board thing inside the black box inside the front door. Thanks
Jeff / APP Team
#2 Posted : Wednesday, February 16, 2011 7:33:00 AM(UTC)
Jeff / APP Team
It sounds like you have a bad key pad. There is a way of testing the ribbon connector on your board, but you will need a multi-meter and micro leads to do this. If you have these tools then I will be glad to help you with the test to be 100% sure. If the unit will work sometimes and sometimes it won't, that is usually the keypad failing. The part number you will need is Part number: AP4365240
Maytag dishwasher won't start unless I manually hold door closed (Dishwasher Repair)
by RepairKing53 1/29/2016 10:14:13 AM(UTC)
Maytag Dishwasher Won't Start... (Dishwasher Repair)
by jd122653 11/8/2013 1:29:47 PM(UTC)
Maytag Dishwasher won't start (Dishwasher Repair)
by tommies1 10/30/2013 10:03:58 PM(UTC)
Maytag dishwasher won't start (Dishwasher Repair)
by WMCCOX 11/1/2012 3:42:59 PM(UTC)
by jd122653 5/4/2012 9:59:03 AM(UTC)
by gunner_1911 9/26/2011 2:20:00 PM(UTC)
by k5wls 7/4/2011 8:01:19 PM(UTC)
by caroltdds 6/3/2011 9:07:05 AM(UTC)
maytag dishwasher won't start (Dishwasher Repair)
by cozzy 4/27/2011 1:21:50 PM(UTC)
Maytag Dishwasher Won't Start (Dishwasher Repair)
by hmanka 8/25/2010 5:12:13 AM(UTC)
by Donw 11/10/2008 1:51:00 PM(UTC)
by Whatnow? 4/15/2008 4:53:13 PM(UTC)
