Hi,My washer doesn't want to spin unless I give it a head start and sometimes that takes a while.It is also leaking from underneath some.I am thinking it may be some kind of bearings or whatever makes the agitator turn.The agitator doesn't seem to turn to wash as fast as it use to either.I'm thinking that it may need a new seal or something for the leaking too.I am not sure.Can someone please help me? Thanks,Heather
Well Heather, not really sure what Barons are :) but it most definatly sounds like your tranny has failed. When a tranny fails you will get the symptoms you described, the leak would be from the seal, and there is a 50/50 shot that the outer tub would need to be replaced if a new seal won't seal.. Either way , it is a rather difficult job for a beginner, and kinda spendy also.
