wkvien
#1 Posted : 14 years ago
wkvien
this oven wont ignite the range burners are ok
#2 Posted : 14 years ago
Does the igniter (#14 on the diagram) glow?
If it does then most likely the igniter itself is too weak to open the gas valve and has to be replaced.
If it does not, then you have to check if there is 120 VAC to the igniter while the oven thermostat calls for Bake and post the results.
- The igniter Part number: AP4012072
Kendall4570
#3 Posted : 11 years ago
Kendall4570
Is this true even if the igniter glows? Our igniter comes on but the valve doesn't open.
Thanks.
Kendall4570
#4 Posted : 11 years ago
Kendall4570
Thanks.
And if this is the case, what is the part number for this igniter?
KitchenAid Gas Oven Wont Ignite (Oven Repair (including Ranges and Cooktops))
by traveller 14 years ago
