wkvien
#1 Posted : Friday, January 28, 2011 12:36:55 PM(UTC)
wkvien
this oven wont ignite the range burners are ok
#2 Posted : Friday, January 28, 2011 5:27:14 PM(UTC)
Does the igniter (#14 on the diagram) glow?
If it does then most likely the igniter itself is too weak to open the gas valve and has to be replaced.
If it does not, then you have to check if there is 120 VAC to the igniter while the oven thermostat calls for Bake and post the results.
- The igniter Part number: AP4012072
Kendall4570
#3 Posted : Saturday, February 1, 2014 6:18:14 PM(UTC)
Kendall4570
Is this true even if the igniter glows? Our igniter comes on but the valve doesn't open.
Thanks.
Kendall4570
#4 Posted : Monday, February 3, 2014 8:43:45 AM(UTC)
Kendall4570
Thanks.
And if this is the case, what is the part number for this igniter?
KitchenAid Gas Oven Wont Ignite (Oven Repair (including Ranges and Cooktops))
by traveller 4/14/2011 2:51:06 PM(UTC)
