Doug J
#1 Posted : Friday, December 5, 2008 4:01:58 PM(UTC)
Doug J
I replaced the old element with a new element and fuse. However, I did not replace the limit thermostat. The reason being, the old thermostat has three terminals; one for a black wire, one for an orange wire, and one on top of the black wire terminal side for a smaller red/yellow wire about 16 gage. The new limit thermostat only has two terminals. One for the black wire and one for the orange wire. What do I do with the red/yellow wire and/or where do I place it? The black wire and the smaller red/yellow wire can be traced up to the control panel on the dryer. Please advise. Thank you.
#2 Posted : Friday, December 5, 2008 6:36:31 PM(UTC)
I believe you have the wrong thermostat
Here is your parts breakdown
Model LEA80AW
You will notice there are two part numbers for the thermostat so I assume the difference is the third terminal which goes to the moisture sensor.
Here is a service manual which includes your unit Page 11-8
http://www.servicematters.com/m...ary/docs/RS3200005R2.pdf
LG DLE 5955 - keeps tripping upper limit thermostat (Dryer Repair)
by gamefixer 3/1/2019 2:40:57 AM(UTC)
Hi Limit Thermostat Keeps Tripping (Dryer Repair)
by dragoscscc 4/16/2016 10:11:15 AM(UTC)
High Limit Thermostat Question (Dryer Repair)
by alawaterdog 10/3/2015 7:25:13 AM(UTC)
High Limit Thermostat (Dryer Repair)
by Eugene Chun 7/23/2015 5:27:36 AM(UTC)
Dryer won't dry replaced, coil, cycling thermostat high limit thermostat (Dryer Repair)
by Replacedeverythingindryer 2/17/2015 2:17:26 PM(UTC)
How To Reset High Limit Thermostat (Dryer Repair)
by scubes 7/21/2014 4:06:28 PM(UTC)
Roper dryer keeps blowing high limit thermostat (Dryer Repair)
by Sparty1721 11/17/2013 8:42:25 AM(UTC)
High Limit Thermostat wire burned (Dishwasher Repair)
by rosskell 11/9/2013 6:49:47 AM(UTC)
Wire connecting heating element and high limit thermostat burned (Dryer Repair)
by stubarnes4prez 9/27/2013 2:55:24 PM(UTC)
Hi-Limit Thermostat (Dryer Repair)
by lakrfan49 9/24/2013 9:39:59 PM(UTC)
Location of high limit thermostat (Dishwasher Repair)
by vinniev 2/18/2013 4:27:09 PM(UTC)
using high limit thermostat in place of thermal cutoff (Dryer Repair)
by deerichards 5/9/2012 12:41:24 PM(UTC)
Wire connection to high limit thermostat (Dryer Repair)
by ctweedy 5/7/2012 2:23:52 PM(UTC)
High Limit thermostate (Dryer Repair)
by dsocha 1/10/2012 5:54:59 PM(UTC)
Crossing wires on Hi Limit Thermostat-LG (Dryer Repair)
by cable18 11/25/2011 2:56:52 PM(UTC)
