Doug J
#1 Posted : 16 years ago
Doug J
I replaced the old element with a new element and fuse. However, I did not replace the limit thermostat. The reason being, the old thermostat has three terminals; one for a black wire, one for an orange wire, and one on top of the black wire terminal side for a smaller red/yellow wire about 16 gage. The new limit thermostat only has two terminals. One for the black wire and one for the orange wire. What do I do with the red/yellow wire and/or where do I place it? The black wire and the smaller red/yellow wire can be traced up to the control panel on the dryer. Please advise. Thank you.
#2 Posted : 16 years ago
I believe you have the wrong thermostat
Here is your parts breakdown
Model LEA80AW
You will notice there are two part numbers for the thermostat so I assume the difference is the third terminal which goes to the moisture sensor.
Here is a service manual which includes your unit Page 11-8
http://www.servicematters.com/m...ary/docs/RS3200005R2.pdf
LG DLE 5955 - keeps tripping upper limit thermostat (Dryer Repair)
by gamefixer 6 years ago
Hi Limit Thermostat Keeps Tripping (Dryer Repair)
by dragoscscc 9 years ago
High Limit Thermostat Question (Dryer Repair)
by alawaterdog 9 years ago
High Limit Thermostat (Dryer Repair)
by Eugene Chun 10 years ago
Dryer won't dry replaced, coil, cycling thermostat high limit thermostat (Dryer Repair)
by Replacedeverythingindryer 10 years ago
How To Reset High Limit Thermostat (Dryer Repair)
by scubes 11 years ago
Roper dryer keeps blowing high limit thermostat (Dryer Repair)
by Sparty1721 11 years ago
High Limit Thermostat wire burned (Dishwasher Repair)
by rosskell 11 years ago
Wire connecting heating element and high limit thermostat burned (Dryer Repair)
by stubarnes4prez 11 years ago
Hi-Limit Thermostat (Dryer Repair)
by lakrfan49 11 years ago
Location of high limit thermostat (Dishwasher Repair)
by vinniev 12 years ago
using high limit thermostat in place of thermal cutoff (Dryer Repair)
by deerichards 13 years ago
Wire connection to high limit thermostat (Dryer Repair)
by ctweedy 13 years ago
High Limit thermostate (Dryer Repair)
by dsocha 13 years ago
Crossing wires on Hi Limit Thermostat-LG (Dryer Repair)
by cable18 13 years ago
