deerichards
#1 Posted : Wednesday, May 9, 2012 12:41:24 PM(UTC)
deerichards
I have read that you can use the high limit thermostat (3390291) in place of the thermal cutoff (3398671). We never leave our dryer unattended so if this is safe I would be happy to do it until our replacement thermal cutoff is received.
Simon / APP Team
#2 Posted : Wednesday, May 9, 2012 1:02:50 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
This are the safety thermostats. I would not recommend to anybody to bypass the safety devise.
Thank you.
Simon.
#3 Posted : Thursday, May 10, 2012 2:57:26 AM(UTC)
I do not understand why you would do that.
Especially when it could burn your house down.
The fuse is an additional safety for the hi-limit which is also a safety device.
If the hi-limit's contacts weld together keeping the heater on all the time then the fuse blows.
Also if the heating coil should ground and then the hi-limit or main thermostat cannot control it then the fuse blows.
So if you have a dryer fire which burns your house down and the insurance company found out that you did this they could say that you are not covered.
If you have a problem with fuses blowing then you have to find the cause.
The hi-limit should regulate the heater so that the fuse does not blow.
Eventually if the unit is running off of the hi-limit it's contacts will weld together.
That is why they include both in the kit, they assume that the hi-limit did not do it's job and is no good.
This is not always true as a grounded element can blow fuses as neither thermostat can control the heater.
