Washer display will power on but machine will not do anything . I spoke with a repair guy and he thinks a valve is stuck or could this be something different.
With this machine it could be anything, but I doubt if it is a stuck valve.
Under the top is a tech sheet that should allow you to put it into a diagnostic mode and an automatic test mode which should generate error codes and help you figure it out.
Originally Posted by: sidfink43 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) With this machine it could be anything, but I doubt if it is a stuck valve.
Under the top is a tech sheet that should allow you to put it into a diagnostic mode and an automatic test mode which should generate error codes and help you figure it out. Sidfink43 can you give information on how to open it up.
