candygaylor
#1 Posted : Saturday, April 30, 2011 12:22:30 PM(UTC)
candygaylor
My Maytag Epic Z will not work on any setting, it has power and does the first little spin hen first turned on but nothing after that, hat could be the problem?
Thanks!
sidfink43
#2 Posted : Sunday, May 1, 2011 7:14:48 AM(UTC)
sidfink43
Hi Candy
I am going to link you to a service manual (be patient it takes a while to download) and you can use the diagnostic process in there to try to determine the problem by generating error codes and doing some testing.
Focus on the main CCU as the likely source of the problem, particularly if you cannot generate error codes or put it into test mode.
Good luck
https://secured.whirlpoo...58f7af/$FILE/8178686.pdf
