anthonyd
#1 Posted : Thursday, January 27, 2011 7:01:05 AM(UTC)
anthonyd
Washer display will power on but machine will not do anything . I spoke with a repair guy and he thinks a valve is stuck or could this be something different.
sidfink43
#2 Posted : Friday, January 28, 2011 8:57:20 AM(UTC)
sidfink43
With this machine it could be anything, but I doubt if it is a stuck valve.
Under the top is a tech sheet that should allow you to put it into a diagnostic mode and an automatic test mode which should generate error codes and help you figure it out.
anthonyd
#3 Posted : Friday, January 28, 2011 9:33:45 AM(UTC)
anthonyd
Sidfink43 can you give information on how to open it up.
sidfink43
#4 Posted : Friday, January 28, 2011 10:17:07 AM(UTC)
sidfink43
No problem. This is coming up as a Whirlpool made Cabrio washer.
Here is a link to a service manual that should set you up fine.
https://secured.whirlpoo...540a8f/$FILE/8178582.pdf
Front load washer will not work in spin cycle (Washer Repair)
by jldmadlove 3/21/2012 10:15:28 AM(UTC)
frontload washer will not work on any setting (Washer Repair)
by candygaylor 4/30/2011 12:22:30 PM(UTC)
washer will not work (Washer Repair)
by SRB 7/31/2008 6:40:12 PM(UTC)
dishwasher will not work (Dishwasher Repair)
by rayjhay 6/24/2008 6:15:38 PM(UTC)
