When i press the knob to start the dryer there is a buzzing noise but the motor wont start.
Sounds like a bad motor or something has it jammed up, see if you can turn the drum by hand to the left....
the drum does turn by hand but it won't start when i try to start it should i order a new moter
Usually a bad motor will make a sort of loud hum, if so just order a new motor at appliancepartspros.
