willie jamerson
#1 Posted : Saturday, January 22, 2011 1:39:37 PM(UTC)
willie jamerson
Views messages in topic : 1
dryer will not start after pushing timer knob.can hear timer clicking,but won't start.
kayakcrzy
#2 Posted : Sunday, January 23, 2011 6:29:06 AM(UTC)
kayakcrzy
Willie, you need to take off the front of the dryer. So first pop up the top, and then there are 2 screws on the inside of the front, about 6 inches from the top on each side. They are 1/4 inch screws. Once those screws are out, remove the wires from the door switch, and then lift up on the front and remove. Look down on the front panel on the bottom, and clean all the lint out. Also stick your hand up there, and get all the lint out you can. Then if you look on top of the burner housing, where the flame goes in, there is a small round part, the size of a dime, with 2 wires coming to it. That will most likely be your culprit. The part # is LA-1053. Make sure you do what I said with the dryer unplugged. The kit comes woth the thermostat that is also mounted to the burner housing. Tom
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
GE dryer timer issue (Dryer Repair)
by Guest 5/8/2024 11:47:16 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
Dryer Timer Humming (Dryer Repair)
by terzolino 4/6/2023 10:18:16 AM(UTC)
Kenmore Dryer Timer Power Resistor Rating (Dryer Repair)
by mhall264 3/19/2021 9:04:39 AM(UTC)
Dryer timer shorting - help me verify my rationale (Dryer Repair)
by jeromio 1/29/2020 6:51:31 PM(UTC)
Whirlpool dryer timer knob (Dryer Repair)
by robertjhebert 10/27/2019 8:50:18 AM(UTC)
Kenmore dryer timer or no timer (Dryer Repair)
by Jester1x 10/25/2019 8:47:13 PM(UTC)
Whirlpool dryer timer won't stop running. (Dryer Repair)
by ppipowerclass 4/2/2018 2:18:22 PM(UTC)
Wiring Help On GE Dryer Timer (Dryer Repair)
by Kierancypher 6/16/2017 11:00:27 AM(UTC)
Dryer Timer Compatibility (Dryer Repair)
by Paulvolter 5/28/2017 6:48:02 PM(UTC)
dryer timer release brackets (Dryer Repair)
by lcolquitt 5/24/2017 2:50:20 PM(UTC)
Kenmore Gas Dryer Timer (Dryer Repair)
by keepitfromthedump 5/24/2017 2:18:27 PM(UTC)
dryer timer will not advance (Dryer Repair)
by Jlb86 2/24/2017 4:24:03 PM(UTC)
