voneta
#1 Posted : 14 years ago
voneta
Code(upside down FE) manual says thermosensor. I was also told to change control panel. We replaced both and we are still getting same code. What else could it be.:confused:
Thermossensor DC32-00010A
Control Panel MFS-F2WLA-T0 / AP4244507
Joe / APP Team
#2 Posted : 14 years ago
Joe / APP Team
Voneta,
You're on the right track, you've done the proper (reccomended)procedure.
But,
With what you've done, the only thing leftto do, would be to check for damaged wires between the thermosensor and the control board.
And check and make sure all your connections are proper and tightly locked into the board connector.
Good Luck,
voneta
#3 Posted : 14 years ago
voneta
We replaced the thermosensor with no luck. We've unplugged all connections no change. We have an ohm meter but my husband doesn't think he will be able to check because he thinks he has to turn switches on and then he doesn't know if they should read open or not. Is this something we can do?
Joe / APP Team
#4 Posted : 14 years ago
Joe / APP Team
Voneta,
Glad you have a meter, it'll make things easier.
Your husband, doesn't have to consider switches for this test.
He does have to make sure he unplugs the power cord,so he doesn't get shocked,
Once he gets access to the control board,
Unplug connector CN3 , across pin 3(white) and pin 6(orange)on the wire connector, he should have a resistance reading of 10 to 13000 ohms resistance at room temperature, if the wires and the sensor are OK.
Also, at RY9(heater relay) pin 1 (red) pin 2 (dbl white) across the two wires, he should read a closed(infinite resistance)circuit, if the heater and fuse are OK.
On rare occasions, a water temperature that's too cold, and a slow fill situation can cause a heater fail code, I don't think that's your problem, but it's a possibilty.
Good Luck,
voneta
#5 Posted : 14 years ago
voneta
Originally Posted by: Joe / APP Team Go to Quoted Post
Voneta,
Good Luck,
Joe, I first want to THANK YOU for helping us with this stipud washer. My husband was able to check the CN3 with a reading of 11.94. However, the RY9 is optional and ours is sealed over with that coating so we were unable to check that one. But I have a question?
We get this code even when we turn on the unit without starting the wash cycle. We are able to start the cycle and the unit starts filling with water and then we get the code. It doesn't matter whether we just brought it to life or put it in spin mode or started a wash cycle. I know it's prolly hard to say but do you really think this has to do with temperture. We are at wits ends. If we had money enough to go buy a new one (a different brand, of course) we would but we don't. Do you have any other thoughts.
I really appreciate all your help.
Voneta
Joe / APP Team
#6 Posted : 14 years ago
Joe / APP Team
Voneta
Voneta,
Thats the way the control board is designed,
As soon as you touch a button, and the display lights up, it starts to run a " test" check on all the components and circuits in the machine, if the "chip" on the control board "sees" what it's looking for it runs the cycle. If it does not, it displays a fail code.
In your case the "tE" code means, that it is not seeing the proper resistance from the thermistor circuit (11.9k ohms is in range, 10 to 13k ohms).
Here are some, low / DC voltage checks at the control board, you can make,
Thermistor Check
Check Voltage at Pin #6 and #3 of CN3
Tester Check = DC2.5V
If it reads 5V, check if its connector is engaged properly.
Water Sensor Check
Check Voltage and Frequency at Pin #6 and #7 of CN3
Reset water level = DC2.5V, 25.8KHz
Check Voltage and Frequency at Pin #6 and #8 of CN3
Sump Sensor Check
Check Voltage at Pin #4 and #2 of CN8
Tester Check = DC0V or 3.75V
Check Voltage at Pin #4 and #3 of CN8
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 9 months ago
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 10 months ago
GE Top load washer not draining (Washer Repair)
by Guest 10 months ago
Washer won’t spin with load (Washer Repair)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 10 months ago
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 10 months ago
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 10 months ago
GE Profile Washer not draining and water not hot (Dishwasher Repair)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 10 months ago
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 10 months ago
Whirlpool duet washer front load (Washer Repair)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 11 months ago
Dishwasher won't work. (Dishwasher Repair)
by Guest 11 months ago
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 11 months ago
GE washer grinding noise (Washer Repair)
by gefixin 11 months ago
