WONT SPIN FAST TO DRAIN THE WATER. IT DISCHARGES SOME WATER AND WHEN IT'S TIME FOR IT TO SPIN FAST,,,,,NOTHING, THE MINUTES COUNT DOWN WHILE THE PUMP IS VIBRATING THEN THE WASHER SHUTS DOWN. CLOTHES STILL SOAKED. I TOOK THE PUMP OFF AND FOUND LOOSE CHANGE IN THE LARGER BLACK HOSE ( COMING OFF THE DRUM ) IS IT POSSIBLE THIS BURNT UP THE PUMP(BLOCKING WATER FROM PUMPING THROUGH?). HOOKED IT BACK UP AND SAME THING. THANKS, :confused:
Take a good look inside the lower service panel and see if there are tech notes that allow you to test some components. Try to test the speed/motor control board, that is a weak point in these machines.
Make sure the drain hoses are free of an blockage, that may also be a problem.
