saveabuck
#1 Posted : Monday, January 17, 2011 6:48:00 PM(UTC)
saveabuck
WONT SPIN FAST TO DRAIN THE WATER. IT DISCHARGES SOME WATER AND WHEN IT'S TIME FOR IT TO SPIN FAST,,,,,NOTHING, THE MINUTES COUNT DOWN WHILE THE PUMP IS VIBRATING THEN THE WASHER SHUTS DOWN. CLOTHES STILL SOAKED. I TOOK THE PUMP OFF AND FOUND LOOSE CHANGE IN THE LARGER BLACK HOSE ( COMING OFF THE DRUM ) IS IT POSSIBLE THIS BURNT UP THE PUMP(BLOCKING WATER FROM PUMPING THROUGH?). HOOKED IT BACK UP AND SAME THING. THANKS, :confused:
sidfink43
#2 Posted : Wednesday, January 19, 2011 6:04:06 PM(UTC)
sidfink43
Take a good look inside the lower service panel and see if there are tech notes that allow you to test some components. Try to test the speed/motor control board, that is a weak point in these machines.
Make sure the drain hoses are free of an blockage, that may also be a problem.
PAVT910AWW Maytag no spin (agitates instead), no refill, no rinse, timer stops. (Washer Repair)
by owkaye 7/27/2022 5:04:45 AM(UTC)
Drains - No Spin (Washer Repair)
by Pallas63 5/20/2022 5:19:47 PM(UTC)
Electolux/Frigidaire fftw4120sw1 agitates, no spin. (Washer Repair)
by wishy_washy 11/19/2021 10:02:42 AM(UTC)
Slow to no spin maytag bravos (Washer Repair)
by Guest 7/28/2021 12:13:49 PM(UTC)
Kenmore Frontload No Spin, but does 2 second fluff spin? (Washer Repair)
by d44boy 3/4/2019 10:18:00 AM(UTC)
Horrible noise and no spin (Washer Repair)
by wilkimtur1 7/19/2018 10:18:41 AM(UTC)
No spin after first one (Washer Repair)
by Jimbobaloue 3/15/2018 1:40:45 PM(UTC)
Whirlpool Gold Ultimate Care II Agitates but no spin (Washer Repair)
by MikeyVdub 1/8/2018 12:49:57 PM(UTC)
GE Washer no spin or agitate (Washer Repair)
by suniack 12/18/2017 7:09:50 PM(UTC)
Agitates and drains but no spin (Washer Repair)
by Burgerpimp 6/7/2017 10:14:27 AM(UTC)
Kenmore 800 Washer no spin on delicate cycle spins fine on others (Washer Repair)
by tedalb 3/27/2017 7:29:52 PM(UTC)
Whirlpool Washer Agitator Noise / No Spin (Washer Repair)
by BobTh 3/1/2017 11:06:09 AM(UTC)
no spin cycle on regular or permanent cycles only delicate cycle (Washer Repair)
by bhartwig 9/3/2016 5:44:07 PM(UTC)
Agitate but no Spin - Brake has lots of grease on it. (Washer Repair)
by movinglikeamovie 8/15/2016 2:27:22 PM(UTC)
Just Humming,No spin,no agitate (Washer Repair)
by buddha131 5/10/2016 3:07:32 PM(UTC)
