When I press the push to start button it starts up but as soon as I let go it stops? do you think it might be the fuse or a relay?
oh thanks i was leaning towards the switch but my husband seems to think it is the relay. we shall see later today. Thanks again,
is the power board the same as the even heat control assembly? if so the part number is #W10116564 correct ? if not what is the part number we cant find it. also here is what i have done - power to PTS is one side and one side of motor relay. power through button both sides and let go it drops off. the book that came with it says the part is called EVEN HEAT CONTROL ASSEMBLY what do you think?
Thank you again Sir I was a bit confused but now I can tell my husband the right part #. Your a life saver.
hello I got my part today from fedex my problem is this i read the tech sheet that came with my dryer on the front cover is states ESD and how the part is to be handled from shipping to installation. it came wrapped in a pink bubble wrap I am not sure if it is screwed up again or what. everyone i call wont tell me anything from the ************************ where it was purchased to whirlpool. Now what I am unemployeed and do not have the funds to keep replacing this part I am just sick about this can you help me??
Tom my part just came and it was wrapped in pink bubblewrap the tech sheet with the dryer says something about ESD and he proper handling of the part from shipping to installation no one will tell me if it is damaged or not and i cant afford to keep replacing this part as it is not cheep and i am not working right now. can you help shed some lite here pls.
