Hi, my roper washer will only fill to about 1/2 to 2/3 the way even when it is set at super. It has always been this way. Is there a way to adjust the water level?
You might want to look at the air hose that goes from the water pressure (level) switch to the tub, to see if it's kinked or pinched somewhere.
Nope the hose is not kinked. Were they set tonly fill half way in oreder to save water? If so, what a bogus way of doing it.
