mike
#1 Posted : Friday, July 20, 2007 2:53:24 PM(UTC)
mike
The ice maker will not fill with water. The water dispenser in the door works. I can fill the ice maker with water and it will make ice. I can see the water in the line at the back of the refrigerator that goes to the ice maker. It just will not fill on it own.
Admin / APP Team
#2 Posted : Saturday, July 21, 2007 9:32:57 AM(UTC)
Admin / APP Team
Rank: Administration
Groups: Guests
Hi Mike,
Most likely the problem is with the water inlet valve. The valve has two solenoids - one solenoid is for the water dispenser and the other is for the ice maker. There is a small chance that the ice maker module may be bad, but sounds like the valve is what you need.
Water valve for your model
Note: Before changing the valve, don't forget to: 1. unplug the refrigerator power cord 2. turn off the water supply to the refrigerator.
Hope this helps.
LG LDC24370ST Ice Maker Issues (Refrigerator & Freezer Repair)
by Guest 6/29/2024 8:55:44 AM(UTC)
Mysterious leak -Top Freezer w/Ice maker (Refrigerator & Freezer Repair)
by St.B 6/18/2024 8:40:52 AM(UTC)
Water Runs Too Long - Ice maker (Refrigerator & Freezer Repair)
by shfdyoung 6/11/2024 3:01:06 PM(UTC)
Bosch Ice Maker Dropping Ice Once Week (Refrigerator & Freezer Repair)
by Guest 5/31/2024 1:40:51 PM(UTC)
Lg ice maker leaking (Refrigerator & Freezer Repair)
by Guest 4/10/2024 2:58:55 PM(UTC)
KITCHEN AID UNDERCOUNTER ICE MAKER KUIC18NNZS0 (Refrigerator & Freezer Repair)
by kwhowell6539 3/25/2024 1:49:40 PM(UTC)
Ice maker slabbing (Refrigerator & Freezer Repair)
by Guest 3/11/2024 8:34:02 PM(UTC)
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
by Eric8888 3/5/2024 11:02:19 AM(UTC)
Installing ice maker, looking for holes (Refrigerator & Freezer Repair)
by Grendel25 2/16/2024 10:02:12 AM(UTC)
ice maker in LG fridge model #LFX31925st/08 (Dishwasher Repair)
by diohabla 2/16/2024 8:36:50 AM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 2/13/2024 4:35:48 AM(UTC)
Ice maker fiil/dump (Refrigerator & Freezer Repair)
by Guest 2/12/2024 5:46:50 AM(UTC)
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice maker issues and more? LG LFX25971 (Refrigerator & Freezer Repair)
by turtlejay 2/1/2024 5:07:00 PM(UTC)
LG French Door can the lower craft ice maker be swapped to cubed? (Refrigerator & Freezer Repair)
by Bstewart63 1/3/2024 11:45:50 AM(UTC)
