mike
#1 Posted : 18 years ago
mike
The ice maker will not fill with water. The water dispenser in the door works. I can fill the ice maker with water and it will make ice. I can see the water in the line at the back of the refrigerator that goes to the ice maker. It just will not fill on it own.
Admin / APP Team
#2 Posted : 18 years ago
Admin / APP Team
Rank: Administration
Hi Mike,
Most likely the problem is with the water inlet valve. The valve has two solenoids - one solenoid is for the water dispenser and the other is for the ice maker. There is a small chance that the ice maker module may be bad, but sounds like the valve is what you need.
Water valve for your model
Note: Before changing the valve, don't forget to: 1. unplug the refrigerator power cord 2. turn off the water supply to the refrigerator.
Hope this helps.
LG LDC24370ST Ice Maker Issues (Refrigerator & Freezer Repair)
by Guest 9 months ago
Mysterious leak -Top Freezer w/Ice maker (Refrigerator & Freezer Repair)
by St.B 10 months ago
Water Runs Too Long - Ice maker (Refrigerator & Freezer Repair)
by shfdyoung 10 months ago
Bosch Ice Maker Dropping Ice Once Week (Refrigerator & Freezer Repair)
by Guest 10 months ago
Lg ice maker leaking (Refrigerator & Freezer Repair)
by Guest 12 months ago
KITCHEN AID UNDERCOUNTER ICE MAKER KUIC18NNZS0 (Refrigerator & Freezer Repair)
by kwhowell6539 about a year ago
Ice maker slabbing (Refrigerator & Freezer Repair)
by Guest about a year ago
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
by Eric8888 about a year ago
Installing ice maker, looking for holes (Refrigerator & Freezer Repair)
by Grendel25 about a year ago
ice maker in LG fridge model #LFX31925st/08 (Dishwasher Repair)
by diohabla about a year ago
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 about a year ago
Ice maker fiil/dump (Refrigerator & Freezer Repair)
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw about a year ago
Ice maker issues and more? LG LFX25971 (Refrigerator & Freezer Repair)
by turtlejay about a year ago
LG French Door can the lower craft ice maker be swapped to cubed? (Refrigerator & Freezer Repair)
by Bstewart63 about a year ago
