The ice maker will not fill with water. The water dispenser in the door works. I can fill the ice maker with water and it will make ice. I can see the water in the line at the back of the refrigerator that goes to the ice maker. It just will not fill on it own.
Rank: Administration
Groups: Joined: 7/18/2007(UTC) Posts: 799
Hi Mike, Most likely the problem is with the water inlet valve. The valve has two solenoids - one solenoid is for the water dispenser and the other is for the ice maker. There is a small chance that the ice maker module may be bad, but sounds like the valve is what you need. Water valve for your modelNote: Before changing the valve, don't forget to: 1. unplug the refrigerator power cord 2. turn off the water supply to the refrigerator. Hope this helps.
