Hi: my duel fuel kenmore elite sears oven shuts down with the code F-1. When I throw the circuit breaker off and back on it clears the F-1. I can then start the oven and get it to the designated temperature but it shuts down after 10 minutes or so and goes back to F-1
sears says we need an electronic clock control (circuit board) and a new sensor probe. Do we need both and why? If so will both fix the problem?
thanks for you help:
martin
""F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)"" ... Unit made by Frigidaire, the fault code list I looked at points to F1 meaning the clock needs to be replaced, not sure about the sensor but if it was mine I would replace both to be safe...;)
