martin
#1 Posted : Friday, October 5, 2007 10:56:19 AM(UTC)
martin
Hi: my duel fuel kenmore elite sears oven shuts down with the code F-1. When I throw the circuit breaker off and back on it clears the F-1. I can then start the oven and get it to the designated temperature but it shuts down after 10 minutes or so and goes back to F-1
sears says we need an electronic clock control (circuit board) and a new sensor probe. Do we need both and why? If so will both fix the problem?
thanks for you help:
martin
Pegi
#2 Posted : Friday, October 5, 2007 1:11:41 PM(UTC)
Pegi
""F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)"" ... Unit made by Frigidaire, the fault code list I looked at points to F1 meaning the clock needs to be replaced, not sure about the sensor but if it was mine I would replace both to be safe...;)
Kitchen Aid Gas Oven Shuts Down (Oven Repair (including Ranges and Cooktops))
by Woodbubba 7/25/2012 6:52:51 AM(UTC)
oven shuts down (Oven Repair (including Ranges and Cooktops))
by dnayden 10/6/2011 12:15:56 PM(UTC)
Display is Dimming and Blinking Before Oven Shuts Down (Microwave Repair)
by Steve Birger 7/28/2010 6:01:11 AM(UTC)
Oven shuts down after 10-15 minutes (Microwave Repair)
by Sempr 3/16/2010 7:49:29 AM(UTC)
