martin
#1 Posted : 18 years ago
martin
Hi: my duel fuel kenmore elite sears oven shuts down with the code F-1. When I throw the circuit breaker off and back on it clears the F-1. I can then start the oven and get it to the designated temperature but it shuts down after 10 minutes or so and goes back to F-1
sears says we need an electronic clock control (circuit board) and a new sensor probe. Do we need both and why? If so will both fix the problem?
thanks for you help:
martin
Pegi
#2 Posted : 18 years ago
Pegi
""F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)"" ... Unit made by Frigidaire, the fault code list I looked at points to F1 meaning the clock needs to be replaced, not sure about the sensor but if it was mine I would replace both to be safe...;)
Kitchen Aid Gas Oven Shuts Down (Oven Repair (including Ranges and Cooktops))
by Woodbubba 13 years ago
oven shuts down (Oven Repair (including Ranges and Cooktops))
by dnayden 14 years ago
Display is Dimming and Blinking Before Oven Shuts Down (Microwave Repair)
by Steve Birger 15 years ago
Oven shuts down after 10-15 minutes (Microwave Repair)
by Sempr 15 years ago
