keister1
#1 Posted : Sunday, November 28, 2010 9:36:00 AM(UTC)
keister1
dryer is not srarting.I checked the door switch for continuity its good.checked the start button its good.checked the thermal switch its showing open.can i put a jump between the two wires to the fuse tosee if that is the only ploblem?? thank you!!
keister1
#2 Posted : Sunday, November 28, 2010 9:39:53 AM(UTC)
keister1
timer is ticking.
#3 Posted : Monday, November 29, 2010 12:32:51 AM(UTC)
I cannot find any info using the given model number.
If it is a thermal fuse that is attached to the blower unit then yes you can jump it.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
If it is a thermal fuse mounted on or near the heating element then there are other things that should be checked.
Thermal fuse ratings and interchangeability on dryers (Dryer Repair)
by Guest 12/17/2023 10:57:55 AM(UTC)
Kenmore Dryer blowing thermal fuses (Dryer Repair)
by Marius 11/21/2023 2:26:28 PM(UTC)
Thermal fuse blown repeatedly (Dryer Repair)
by Guest 3/5/2023 6:13:36 PM(UTC)
Thermal Fuse on KitchenAid KDTE304DSS0 (Dishwasher Repair)
by jztjzt 7/24/2022 7:04:23 PM(UTC)
Matag Bravos gas dryer thermal fuse (Dryer Repair)
by Maytag Bravos Fool 11/29/2021 4:32:35 AM(UTC)
Magic Chef thermal fuse equivalent (Microwave Repair)
by bassclef78 10/13/2021 9:40:22 AM(UTC)
KitchenAid Dishwasher KUDS30IXBL Thermal Fuse (Dishwasher Repair)
by Ed Explains It 3/16/2021 10:34:44 AM(UTC)
Whirlpool Duet Dryer - WED9200SQ0 - Thermal Fuse (Dryer Repair)
by cjmatthes 1/17/2020 2:09:48 PM(UTC)
Electrolux dryer thermal fuse (Dryer Repair)
by Lillydz101 8/14/2019 8:59:05 PM(UTC)
Kenmore Elite dishwasher 665.13112K700 blows thermal fuse (Dishwasher Repair)
by rrsteven 10/31/2018 9:02:16 PM(UTC)
Dryer too hot flips the thermal fuse (Dryer Repair)
by Maverick1 12/6/2017 6:29:07 AM(UTC)
Whirlpool Dryer keeps blowing thermal fuse (Dryer Repair)
by MSUspartan25000 9/6/2017 3:11:10 PM(UTC)
Ikea Whirlpool IBS550PWW00 In wall oven Control Thermal Fuse?? (Oven Repair (including Ranges and Cooktops))
by teamlouish 3/29/2017 3:54:29 PM(UTC)
Whirlpool dryer-thermal fuse keeps blowing (Dryer Repair)
by daddjdom 3/28/2017 9:44:13 AM(UTC)
Kenmore problems/thermal fuse/temp adjustments (Dryer Repair)
by Kruegerk 2/12/2017 5:07:37 PM(UTC)
