fastestbbc
#1 Posted : Monday, November 22, 2010 10:19:25 AM(UTC)
fastestbbc
Hello I have an older GE propane dryer that has been unstoppable till now. The drying cycle has increased considerable. I have verified there is no lint with in the dryer, in the tube or at the house exit. nor has anthing changed in the this area. I have verified the thermistates have continuity and that they function with some amount of heat applied (via hair dryer). the gas ignitor works fine on initial start up so I don't believe there is an issue there during the run time. the only thing I can find that doesn't function 100% is the timer. Of the 3 settings Auto Cotton, Auto Permanent Press and Incremental time setting, only the time setting still works. The auto cotton died first. Also inorder to have anything dry the "high heat" button has to be selected on the push button side.
What are the thoughts? My initial is replacing the Timer but hate to drop $100 on a part if I am missing something. thanks for the assistance.
kayakcrzy
#2 Posted : Tuesday, November 23, 2010 4:22:18 AM(UTC)
kayakcrzy
I would not replace the timer!!! The problem could most likely be the coils on the gas valve are failing. I would replace the coils on the gas valve. Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
fastestbbc
#3 Posted : Tuesday, November 23, 2010 5:31:35 AM(UTC)
fastestbbc
Thanks Tom I will give that a try.
kayakcrzy
#4 Posted : Tuesday, November 23, 2010 3:36:00 PM(UTC)
kayakcrzy
Good Luck!! Tom
GE Profile dryer takes a long time to dry clothes (Dryer Repair)
by mom2ahnika 9/4/2012 11:44:14 AM(UTC)
Maytag dryer takes a long time to dry (Dryer Repair)
by Rocguy 12/31/2011 9:45:06 AM(UTC)
Dryer Takes Long Time to Dry (Dryer Repair)
by AmberJ 10/8/2011 11:05:16 AM(UTC)
Dryer taking a long time to dry clothing (Dryer Repair)
by soldierswife25 9/22/2011 3:54:07 PM(UTC)
Dryer starts out hot but then never drys then takes a very long time to dry cloths (Dryer Repair)
by rcaterina 8/27/2009 8:12:27 AM(UTC)
Dryer taking a long time to dry cloths (Dryer Repair)
by rchomestead 6/16/2009 5:55:30 PM(UTC)
Dryer takes a long time to dry (Dryer Repair)
by amonard 4/9/2009 5:47:03 PM(UTC)
whirlpool gas dryer taking a long time to dry (Dryer Repair)
by mifisher 12/1/2008 4:32:11 PM(UTC)
Dryer Heats, but Takes a Long Time to Dry Clothes (Dryer Repair)
by 95breckut 8/23/2008 8:24:51 AM(UTC)
