TimMN
#1 Posted : Wednesday, November 17, 2010 7:24:21 PM(UTC)
TimMN
I have a gas dryer that won't heat
History;
About a month ago, the dryer started to stop heating about amonth ago. I checked and cleaned the exhaust run, but it was pretty clean. A few days ago, it stopped heating completely
What I know;
The exhaust run is clean - no obstructions.
When I take off the front panel, and air gets in between the air duct assemblya dn blower assembly, the gas 'allowed' to start and to ignite. If the air duct assembly and blower assembly are held tight, the ignitor glows hot, but hten shuts off. It appears something is not allowing the gas to enter (controlling the gas solenoid).
So, looking at the blower assembly, there are two sensors - The thermal fuse and the thermistor.
The thermal fuse has a continuity reading of 0.
The thermistor has a continuity reading of 11.3 at 200K Ohms, and drops to around 7 when heat is applied.
I would assume the thermistor is the culprit, how does the air entering between the air duct assembly and the blower assembly affect the system? If it wasn't for that, it seems pretty straight forward.
Thanks for any ideas!
TheFixItKid
#2 Posted : Thursday, November 18, 2010 5:28:21 PM(UTC)
TheFixItKid
HELLO .......IF PART IS READING ZERO WITH CONTINUITY TEST USUALLY INDICATES A PROBLEM SEE DIAGRAM NUMBER 3 AND LOOK AT PICTURES PROBABLY GONNA BE NUMBER 35 THE THERMAL FUSE BUT ALSO COULD BE NUMBER 13 THE FLAME SENSOR WHICH SENSES HEAT FROM THE IGNITOR AND ALLOWS GAS VALVE TO OPEN AND CLOSE AS NECESSARY
There are five major electrical parts involved in the heating process:
1. Thermal fuse
2. Cycling thermostat
3. Igniter
4. Flame sensor
5. Gas valve coils
If any of them is open – it has to be replaced.
If the thermal fuse is blown – it has to be replaced together with the cycling thermostat.
HOPE MY INFORMATION CAN HELP PROVIDE RESOLUTION ........
Guest (4)
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Gas dryer won't heat (Dryer Repair)
by pino2424 4/21/2015 5:45:55 PM(UTC)
Kenmore Gas Dryer won't Heat (Dryer Repair)
by rboysen 2/5/2014 5:57:38 AM(UTC)
Signature Gas Dryer Won't Heat (Dryer Repair)
by jsellnow 1/24/2014 9:10:42 AM(UTC)
LG gas dryer won't heat up (Dryer Repair)
by Farmer85 10/2/2013 9:21:16 AM(UTC)
Whirlpool Gas Dryer Won't Heat (Dryer Repair)
by jonellem 2/3/2013 7:27:46 PM(UTC)
Whirlpool Duet Gas Dryer Won't Heat Up (Dryer Repair)
by evanr99 2/1/2013 6:16:21 PM(UTC)
by Clueless2 5/30/2012 9:02:40 AM(UTC)
by ejohnso6 4/21/2012 7:30:36 AM(UTC)
by markdeveer@gmail.com 12/23/2011 9:36:52 AM(UTC)
by sunshine2 5/19/2011 8:06:36 AM(UTC)
GE gas dryer won't heat (Dryer Repair)
by deadmusk 1/15/2011 11:27:35 AM(UTC)
Brand New Gas Dryer Won't Heat (Dryer Repair)
by AMLove 12/19/2010 3:47:49 AM(UTC)
by ikohn 11/14/2010 3:40:40 PM(UTC)
by scolmery 10/27/2010 6:35:31 PM(UTC)
