I have a Duet dryer that won't start. When I push the start button I can hear it click through the curcuit baord and all I get is the sensing light. What should I look at?
Remove the front bottom access panel and check the belt. If the belt is broken then there is a broken belt switch (#5 on the diagram). The second part in question is the thermal fuse (#47 on the diagram) which has to be tested for continuity. - The belt Part number: AP2911808
