pkreiner
#1 Posted : Tuesday, November 9, 2010 8:40:31 AM(UTC)
pkreiner
I have a Duet dryer that won't start. When I push the start button I can hear it click through the curcuit baord and all I get is the sensing light. What should I look at?
#2 Posted : Tuesday, November 9, 2010 3:10:37 PM(UTC)
Remove the front bottom access panel and check the belt. If the belt is broken then there is a broken belt switch (#5 on the diagram). The second part in question is the thermal fuse (#47 on the diagram) which has to be tested for continuity.
- The belt Part number: AP2911808
- The broken belt switch Part number: AP3094230
- The thermal fuse kit (including the high limit thermostat) Part number: AP3094323
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
Whirlpool Dryer Won't Start- Help! (Dryer Repair)
by NikTy15 5/3/2015 6:59:24 AM(UTC)
Whirlpool dryer won't start (Dryer Repair)
by cmarley304 8/19/2014 6:07:34 PM(UTC)
by jdbell1114 3/17/2014 5:58:20 PM(UTC)
by emontoute 8/4/2013 10:01:22 AM(UTC)
by Turtleman1961 1/18/2013 5:52:20 PM(UTC)
Whirlpool Dryer won't start (Dryer Repair)
by adsch 6/26/2012 7:55:27 PM(UTC)
Whirlpool Dryer won't start - buzzing (Dryer Repair)
by David Mitchell 1/14/2012 11:52:35 AM(UTC)
by gunworks 12/14/2011 6:47:15 PM(UTC)
by patarnotte@comcast.net 12/6/2011 1:57:13 PM(UTC)
Whirlpool Dryer won't start, but hums (Dryer Repair)
by gmreeves2 12/1/2011 8:16:57 PM(UTC)
by JWCL 11/29/2011 6:43:51 AM(UTC)
by moonie777 5/13/2011 8:59:04 AM(UTC)
by zebra47cb 2/24/2011 2:53:01 PM(UTC)
Whirlpool Dryer won't start in dryer mode. (Dryer Repair)
by hol99 12/24/2010 1:06:56 PM(UTC)
