mylene4u
#1 Posted : Monday, November 3, 2008 7:19:56 AM(UTC)
mylene4u
I am really in need of some help here. I have this gas dryer that wont heat. I looked on this forum and pulled it out and replaced the thermal fuse, and both thermostats, and the flame sensor. It still does not heat. I dont believe there is an element for this dryer. I know it is a 110 dryer and the power to it is just fine. I am wondering what step I should take next to get this dryer to heat for me. :mad:
abvipacifica1
#2 Posted : Monday, November 3, 2008 7:50:52 AM(UTC)
abvipacifica1
Originally Posted by: mylene4u Go to Quoted Post
I am really in need of some help here. I have this gas dryer that wont heat. I looked on this forum and pulled it out and replaced the thermal fuse, and both thermostats, and the flame sensor. It still does not heat. I dont believe there is an element for this dryer. I know it is a 110 dryer and the power to it is just fine. I am wondering what step I should take next to get this dryer to heat for me. :mad:[/qu:confused: ote]
kayakcrzy
#3 Posted : Monday, November 3, 2008 1:41:17 PM(UTC)
kayakcrzy
Does the ignitor come on? Also do you have a meter? Tom ApplianceEducator.com
mylene4u
#4 Posted : Tuesday, November 4, 2008 4:51:31 AM(UTC)
mylene4u
I have a gas meter, since were are in a rural area. I am not sure if the ignitor comes on? Would you have to take off the back or the front to check that out?
magician59
#5 Posted : Tuesday, November 4, 2008 6:02:17 AM(UTC)
magician59
There are a couple ways you can check to see if the igniter comes on. One is: If you have a small inspection panel on the front of the dryer, remove it by prying outward on one of the edges, and see if the igniter glows a few seconds after you start the dryer. If there is no such panel, you can still check, if you can make the room as dark as you can. Then, see if there is a glow coming from under the machine a few seconds after it starts. If the igniter glows, then goes out a few seconds later with no flame, the solenoid coils may need to be replaced.
Dryer will not heat (Dryer Repair)
by MByram 4/22/2018 8:36:12 PM(UTC)
Dryer Will Not Heat (Dryer Repair)
by coreyhall 3/6/2017 10:18:48 AM(UTC)
Dryer will not heat or turn off (Dryer Repair)
by jesus freak 1/17/2016 2:25:22 PM(UTC)
by rwebb 12/4/2015 9:44:48 AM(UTC)
Dryer will not heat and will not shut off (Dryer Repair)
by HMH1983 9/23/2015 6:44:16 PM(UTC)
Default Dryer will not heat, timer does not work (Dryer Repair)
by gotcoffee82 3/1/2015 7:37:21 PM(UTC)
Dryer will not heat up (Dryer Repair)
by kpholler 12/2/2014 3:42:57 PM(UTC)
Gas dryer will not heat up (Dryer Repair)
by Ahhnother8 10/9/2014 8:16:39 PM(UTC)
Kenmore Dryer Will Not Heat After Replacing Everything (Dryer Repair)
by jlewis57 10/1/2014 12:28:50 PM(UTC)
Dryer will not heat and timer will not advance (Dryer Repair)
by MNJames 9/15/2014 2:46:05 PM(UTC)
Dryer Will Not Heat, But All Parts Test OK (Dryer Repair)
by kamera 9/6/2014 9:33:05 AM(UTC)
Roper dryer will not heat (new parts installed too) (Dryer Repair)
by xenomorphlv426 2/1/2014 8:49:03 AM(UTC)
GE harmony profile gas dryer will not heat (Dryer Repair)
by Thespiderman20 9/10/2013 5:44:45 PM(UTC)
Dryer will not heat. (Dryer Repair)
by modelshop8624 7/4/2013 1:24:12 PM(UTC)
Kenmore Dryer will not heat but the drum runs (Dryer Repair)
by asirota1 3/25/2013 8:33:52 AM(UTC)
