ctct703
#1 Posted : 17 years ago
ctct703
Dryer works fine except it will not heat. This is an electric dryer. The heating element and sensor at the element both ohmn out to be good. What else?
#2 Posted : 17 years ago
Make sure you get 230 volts to the dryer. If ok, check the thermal fuse and heating element for continuity. You can click on your model # above to get parts.
Dryer will not heat (Dryer Repair)
by MByram 7 years ago
Dryer Will Not Heat (Dryer Repair)
by coreyhall 8 years ago
Dryer will not heat or turn off (Dryer Repair)
by jesus freak 9 years ago
by rwebb 9 years ago
Dryer will not heat and will not shut off (Dryer Repair)
by HMH1983 9 years ago
Default Dryer will not heat, timer does not work (Dryer Repair)
by gotcoffee82 10 years ago
Dryer will not heat up (Dryer Repair)
by kpholler 10 years ago
Gas dryer will not heat up (Dryer Repair)
by Ahhnother8 10 years ago
Kenmore Dryer Will Not Heat After Replacing Everything (Dryer Repair)
by jlewis57 10 years ago
Dryer will not heat and timer will not advance (Dryer Repair)
by MNJames 10 years ago
Dryer Will Not Heat, But All Parts Test OK (Dryer Repair)
by kamera 11 years ago
Roper dryer will not heat (new parts installed too) (Dryer Repair)
by xenomorphlv426 11 years ago
GE harmony profile gas dryer will not heat (Dryer Repair)
by Thespiderman20 12 years ago
Dryer will not heat. (Dryer Repair)
by modelshop8624 12 years ago
Kenmore Dryer will not heat but the drum runs (Dryer Repair)
by asirota1 12 years ago
