Dryer makes a screeching sound all throughout the drying cycle.
Originally Posted by: Bethl613 Dryer makes a screeching sound all throughout the drying cycle. Beth, A high pitched screeching noise in that style unit is usually due to a bad drum bearing assembly, Part number: AP2142648
There could be other things (idler pulley, glides, something in the seal) but that's the most likely problem. Good Luck, :) :) :)
