Gofastdriver
#1 Posted : Wednesday, December 3, 2008 2:11:55 PM(UTC)
Gofastdriver
I have replaced both roller assemblies, and found a screw fell out of the heater housing which I replaced, but the squeal is just as load. is it the idler pulley or the bearings? What parts will I need?
#2 Posted : Wednesday, December 3, 2008 3:53:56 PM(UTC)
Here is the parts breakdown
Model MDE9806AYW
Open it up and check the following for wear and/or slop
Idler wheel and shaft
Front glides Item 30 in Tumbler section (Kit-bearing)
Spin the motor to be sure the bearings are OK and that the blower is not rubbing on the housing.
Here is a good link - check out #25 & 26
http://www.applianceaid.com/maytag-dryers.html
