I have replaced both roller assemblies, and found a screw fell out of the heater housing which I replaced, but the squeal is just as load. is it the idler pulley or the bearings? What parts will I need?
Here is the parts breakdown Model MDE9806AYWOpen it up and check the following for wear and/or slop Idler wheel and shaft Front glides Item 30 in Tumbler section (Kit-bearing) Spin the motor to be sure the bearings are OK and that the blower is not rubbing on the housing. Here is a good link - check out #25 & 26 http://www.applianceaid.com/maytag-dryers.html |
THIS FORUM IS DEAD!!!!!!! |
